Tire-pressure sensors for normal cars are mostly made for lower pressure, so they get inacurate above a sertain pressure ( mostly 4 bar /60 psi. For that reason its also not a good idea, or your dodge is already working with high pressures.
If your damage was done by to low pressure, so sidewall damage or treath coming loose, and no nail or stone piercing the treath or sidewall, its better to review the pressure-advice .
You can do that with my made motorhome-tire-pressure-calculator.
Can be found in this map on my skydrive that belongs to my hotmail adres with same username as here.
Motorhome-tire-pressure-calculatorFirst download by
RIGHTCLICKINGand then choose
Download.
Not leftclick and dont choose open in Excell or Web app, to complicated or goes wrong.
After download and eventual virus-check , open in Excell or Open Office CALC on your computer to use it.
If you cant work it out , give me the details of trailer and tires, and I will do it for you.
