gmw_photos
Mar 15, 2015Explorer
Briand wrote:
Lots of misinformation and confusing information here. If you want to get the most miles out of your tires, most even wear and carry the heaviest load, then inflate tires to the MAXIMUM that they specify on the side wall. I have never had a tire that did not state 2 pressures. Min and max.
I will respectfully disagree with most of that post.
See my earlier post about the P tires on my Nissan truck. And to add to that, the tires ( 80 psi rated, load range E, BF Goodrich LT ) on our F350 diesel dually are maintained at door sticker stated pressure ( 60 rear, 75 front ). The truck is used almost exclusively for towing two different trailers loaded to 13 to 14K pounds. Original tires went 50K miles, and were wearing perfectly even, still had half their original tread. Replaced due to age and beginning to suffer weatherchecking.
Point is, max sidewall pressure is often not needed nor desirable, in my opinion. Y'all's mileage, tires, experiences and opinions will likely vary.
