- CGRetiredExplorerAlso interesting to note in that sticker picture...the spare is a 16 inch tire and the rest are 17 inch...? Interesting...what kind of vehicle is that?
- MarkTwainExplorer
Thsldo wrote:
I also experienced a squishy feeling when towing with the trucks suggested PSI. Once I aired up to the sidewall max, towing was night and day. Trailer tires, aired to the max, truck front and rear aired to the max. I keep it like that during the camping season, and then drop it back down to the truck recommended after the camping season is over, or if I am going on a trip without the camper. As for the rough ride, it's barely noticeable.
Recommend "E' rated tires and if possible 16" wheels. - rbpruExplorer IIMy 2011 F-150 4X4 came with the standard Wrangler 275/65r 18 Type P tires. I have 33,000 miles on them about 11,000 towing miles. They have a max pressure of 44 psi. stamped on the side wall, I tow with 40 psi rear and 38 psi front and have had no towing issues with a 5000 lb. dry weight TT.
I expect to get another season out of them then I thought I might switch to LT type tires. Some have even recommended load range āEā replacements.
A quick look at the truck specs shows the following, the front axle is rated for 3750 lbs. the rear axle is rated for 3850. Each of the P type tires have a 2601 lb. max rating stamped on the side wall for a combined rating of 5201 lbs. This puts the tire ratings 1400 lbs. over the axle rating.
A pair of load range Ds would provide an additional 45 lbs. of load capability and load range Es would give me 2234 lbs. more capacity than the TV axle rating and of course have no effect on the max cargo capacity.
Now I understand that because of sway, proposing or a general squishy feel, some people want the benefit of the added sidewall stiffness of the higher load range tires. However I consider my towing performance quite good and the ride of the TV when not towing more than firm enough without adding stiffer tires.
I suspect I will stick with what the TV maker recommends, they have been at it a long time. - ThsldoExplorerI also experienced a squishy feeling when towing with the trucks suggested PSI. Once I aired up to the sidewall max, towing was night and day. Trailer tires, aired to the max, truck front and rear aired to the max. I keep it like that during the camping season, and then drop it back down to the truck recommended after the camping season is over, or if I am going on a trip without the camper. As for the rough ride, it's barely noticeable.
- coolbreeze01Explorer
APT wrote:
This sticker lists what the vehicle manufacturer recommends for tire pressures as a compromise of ride/handling and comfort. It also must be capable of handling the vehicle's load at GVWR.
Many people have experienced that a little higher pressure when the vehicle is closer to GVWR than unloaded provides a better ride and handling.
Worth noting that the spare is filled to 80psi. Curious what the OP's spare tire is aired too? - gmw_photosExplorerMy little truck ( Nissan Frontier ) has "P" tires. Normal inflation is 35 psi. Max on the sidewall is 44. I tried 44 on the rear while pulling the trailer and discovered that was over-inflated. Even loaded up, the outside rib of the tires was not touching the pavement.
I settled on 36 front and 38 rear in my case, and this seems to work well. The truck handles correctly, the tires wear evenly, and run cool even on hot days at highway speed all day.
Y'alls mileage, tires, pressures and experience may vary.
As for "squishy handling", the biggest change I noticed regarding that was removing the load range C ST tires from the trailer, replacing them with load range D LT tires. Much better towing experience.
EDIT: another improvement to the stability of the towing with this combo was replacing the OE shocks on the back of the truck. I installed monroe sensa-tracs at first, and they were an improvement. I have since replaced those with billstein 5100's, and those were another step up in improvement. - RJCorazzaExplorerI generally avoid the tire pressure threads, but weighing in on P rated tires in general:
With the loaded weights of tow vehicles, running P rated tires can make for a less than desirable towing experience. If the OP has P rated tires and is not able or willing to upgrade them, then I personally would air up to the max sidewall pressure. In practically all other cases I air up based upon actual loads using the tire manufactures load table. IMHO, YMMV - APTExplorerThis sticker lists what the vehicle manufacturer recommends for tire pressures as a compromise of ride/handling and comfort. It also must be capable of handling the vehicle's load at GVWR.
Many people have experienced that a little higher pressure when the vehicle is closer to GVWR than unloaded provides a better ride and handling. - 2oldmanExplorer IIA small truck then.. got it.
- MarkTwainExplorer
Bobbyg2013 wrote:
should I increase the rear tire pressure by 10 psi, on my truck's tires or leave at the suggested 35 psi that is shown on the sticker on the door jam?
What kind of tire?
What size?
What is the tire load range?
What is the weight of the trailer"
Go with the recommended PSI written on the side of the tire! Not the PSI on the inside of your vehicle, that assumes that the tires the truck came with are the same tires you have on your truck today.
44,056 PostsLatest Activity: May 04, 2014
