jimh406
Aug 07, 2017Explorer III
I'd probably look at load inflation charts for those tires, but the tires won't be worse for wear at max pressure. The handling will be different, and you could get some abnormal tire wear especially when unloaded.
The tire ratings in the door are designed to give you a guide for what is the pressure you should run at sticker max GVWR.
