Grit_dog
Aug 09, 2017Trailblazer
51 would be the number with a load. Thise tires are rated for like 2500lbs or so, correct?
Empty 1/2 ton you have about 2500lbs on the rear axle. Add the camper puts you pretty close to max.
Front axle likely won't have much addl weight, depending on the campers center of mass, but the stiffer handling will be welcome so I'd run the fronts at the max too.
