Kayteg1
Aug 09, 2017Explorer II
jimh425 wrote:
I'd probably look at load inflation charts for those tires, but the tires won't be worse for wear at max pressure. The handling will be different, and you could get some abnormal tire wear especially when unloaded.
The tire ratings in the door are designed to give you a guide for what is the pressure you should run at sticker max GVWR.
Would have to double check it, but all my vehicles do have double chart for light load and heavy load.
Good tire manufacturers will publish charts with recommended pressure at given load.
If you can't find one, rule of thumb is to inflate to the same % of max pressure what % of max load you are carrying.
Than again - all you will loose riding at max tire pressure is comfort, while you will save fuel .
