lawrosa
Aug 09, 2017Explorer
OK so now Im confused. Can I up the back to 51 PSI or not? Im not an expert. I was going to but after reading the last post, Im not so sure. Thank you.
Listen clearly. There were questions asked and you didnt answer.
You can put whatever pressure you want in the tires you have from the 35psi whats on your door tag to the 51 psi on the side wall.
Here is the thing though.
1. If you have P rated tires the side wall max load rating on the sidewall gets derated some 9%.
That was 2238 lbs per tire. Not the 2460 it states on the sidewall.
Those P rated tires will carry that derated weight whether you put 35 psi in or 51 psi in the tires.
51 psi may stiffen the tire up some but its still a 2 ply sidewall marshmellow.
You will not get a higher rating on a p rated tire running more air in it.
2. Now if they are LT tires then @ 51 psi you will carry the full load of what the side wall says of 2460 lbs.
LT tires have inflation charts. 2460 @51 psi, 2200 lbs @ 44 psi, 1950 lbs @ 40 psi, etc etc...
Example:
LT 265/70/17 or 265/70/17. Same tire but different because of the "LT" on the sidewall. You also may have an "XL" on the side wall.
But if you dont want to tell us then go ahead and put 51 psi in the tires.
I guess it dont matter.
For my P rated tires of a 35 psi door tag I put 40 psi in when towing. My max on sidewall is 44 psi.
When I put the LT tires on when these wear out I will inflate to the max 44 psi on the side wall when towing.
