lawrosa
Aug 09, 2017Explorer
Grit dog wrote:
Yes you can air up to what the tire says.
Your little camper will be about 2000lbs if your lucky. Get any flavor of load range E tires so you can stiffen up the back. Will be a much better ride in your half ton. And you can air back down to 35psi when you don't have the camper.
Isnt that bad advice telling him to put a load range E on a truck with P rated tires ( most likely) and rims?
Rims are not rated for those higher pressures, and the idiot at the store will probably not be smart enough to put rigid valve stems on too.
