mkirsch
Aug 10, 2017Nomad II
It's not that complicated.
What most people are telling you here is that IT DOES NOT MATTER. 35PSI or 51PSI, those P-metric passenger car tires have the SAME LOAD CARRYING CAPACITY.
Try 35PSI and see if you like it. Try 51PSI and see if you like it better or worse. Try some pressures in between.
Unless you are just absolutely nerve-dead, you will know quickly if there are any problems. Use your common sense, TURN AROUND, and limp home if you don't like how things feel.
