Grit_dog
Aug 10, 2017Trailblazer
lawrosa wrote:Grit dog wrote:
Yes you can air up to what the tire says.
Your little camper will be about 2000lbs if your lucky. Get any flavor of load range E tires so you can stiffen up the back. Will be a much better ride in your half ton. And you can air back down to 35psi when you don't have the camper.
Isnt that bad advice telling him to put a load range E on a truck with P rated tires ( most likely) and rims?
Rims are not rated for those higher pressures, and the idiot at the store will probably not be smart enough to put rigid valve stems on too.
Since you're the tire expert, how do you know the rims aren't rated for a higher pressure? I can't dispute that with Internet data, no can I dispute the 9% de rate thing I guess . Which is also some buried away in the books theory by the tire industry I guess? Also mentioned dropping another 20% to get to the "full time" weight rating vs the "max load" rating. By the time you do all that, the tire won't hold the vehicle itself p, almost. Found a couple articles discussing it, but if it was real, trucks with P tires would come with a big placard on the dash warning that the tire ratings ON the tires was not valid.
Maybe I'm just ignorant and lucky, but I've been putting D or E load tires on half tons for going on 30 years. Even running 60-70-80 psi at times hauling loads way to heavy for the trucks' ratings never popped a rim.
Yours and capris paragraph of theory are akin to the vehicle weight cops except you're tire weight cops.
Unless you can cite some real over inflation catastrophies or something, I'll consider it internet drivel and not be concerned with E tires on my half ton.
Again, some folks on here live in the real world, others will reccomend 1 ton duallies to pull pop up campers.
And FWIW, the new HD Rams have "soft" valve stems with 80 psi tires. Worked fine for years now.
