rwiegand wrote:
The "sticker" pressures are largely based on ride comfort at some assumed typical (low) load The tire labels are related to the load capacity of the tire. Go with the tire manufacturer if you are pushing towards the load limit on the truck. You're trying to have the tire be in full, even contact with the road, all the way across the width of the tire. If your tires wear more in the center your pressure is too high, if they wear at the edges it is too low for your load.
Agree 100%... couldn't have said it better myself.
I seldom drive my truck empty. I just got new shoes on my truck, tire dealer only inflated them to 85psi. Thought it was odd it was riding so smooth back from the tire dealer. First thing I did was pump them up to 105psi. The new tires are rated to be at 110, I go just a touch low when cold to compensate for road heat.
