towpro
Jul 11, 2015Explorer
Tire PSI/load with camper
The tire pressure marked on the sidewall of the tire, is at max load.
Using tire pressure charts, here is my figures.
New truck has 235/80r17-E tires on the back. 4 of them.
The weight on the rear axle with the camper (and trailer) installed is 6700 lbs (this includes truck weight)
6700 lbs divided by 4 tires = 1675 lbs load on each rear tire.
Looking up the tire inflation guide, I see the following pressure recommendations for dual use (per tire):
1570 = 35psi
1870 = 45psi
2155 = 55psi
2470 = 65psi
2687 = 75psi
So this is telling me I should be running around 40 psi in each rear tire for this amount of weight?
Do you agree or would you use different tire pressure?
1570 = 35psi
1870 = 45psi
2155 = 55psi
2470 = 65psi
2687 = 75psi
