- d3500ramExplorer IIINo apologies necessary... I leaned something.
I was not aware of those meanings and terms.
Member "enblethen" would not have replied had you not posted your data...
so it's all good.
Thanks :) - jaycocreekExplorer II
Where does it mention weight rating ?
Yup I totally missed the mark on that post...I tried to look them up and I'm totally confused now..:B
Disregard sorry. - My wheel rating is right after the wheel identification. It would normally be stamped 1350, 1500 or 1980. Should have maximum air pressure as well.
- ticki2Explorer
jaycocreek wrote:
Maybe they quit doing it but as I mentioned,mine was on the factory window sticker..example...Factory window sticker wrote:
(6) 6.0K 8-hole wheels
Pwr steering
37.2 gallon fuel tank-inc: auxiliary fuel tank
Rear vinyl jump seat
Black scuff plates
Black vinyl steering wheel
Voltmeter, oil pressure/temp/fuel gauges w/indicator lights
Trip odometer
Inside hood release
Side window demisters
4 air registers
Electronic AM radio w/digital clock/2 door mounted speakers
Color-keyed instrument panel w/black appliques
Locking glove box
Cigarette lighter
Pwr point
12" day/night mirror
Color-keyed door trim panel w/black handles/reflector
Color-keyed cloth headliner
Color-keyed vinyl sun visors
Where does it mention weight rating ? - ticki2Explorer
enblethen wrote:
Rating is stamped on the inside of rims.
Wheel identification
No where in that link does it mention weight rating unless I missed it - It is a 6.0 inch wide rim the K indicates the type of tire bead.
~snip~
I am not sure how to interpret that data. That is, not sure what "6.0K" means. It seems qty=6 so assuming it is a dually truck, but cannot imaging each one has a 6K (pounds???) rating. That seems very high for each wheel. Consequently, If the total rating is 6K in that each one is only rated for 1,000 pounds then that seems awfully low. - jaycocreekExplorer IIMaybe they quit doing it but as I mentioned,mine was on the factory window sticker..example...
Pwr steering
Black scuff plates
Trip odometer
Inside hood release
4 air registers
Locking glove box
Cigarette lighter
Pwr point
Color-keyed vinyl sun visors - Grit_dogNavigator II3500-3600lbs for most OE 8 lug rims
- billtexExplorer III have looked at GM and Ford OE wheels both alum and steel and have never found the rating marked on the wheel.
Good luck with your search.
44,043 PostsLatest Activity: May 03, 2014
