- d3500ramExplorer IIINo apologies necessary... I leaned something.
I was not aware of those meanings and terms.
Member "enblethen" would not have replied had you not posted your data...
so it's all good.
Thanks :) - jaycocreekExplorer II
Where does it mention weight rating ?
Yup I totally missed the mark on that post...I tried to look them up and I'm totally confused now..:B
Disregard sorry. - My wheel rating is right after the wheel identification. It would normally be stamped 1350, 1500 or 1980. Should have maximum air pressure as well.
- ticki2Explorer
jaycocreek wrote:
Maybe they quit doing it but as I mentioned,mine was on the factory window sticker..example...Factory window sticker wrote:
(6) 6.0K 8-hole wheels
Pwr steering
37.2 gallon fuel tank-inc: auxiliary fuel tank
Rear vinyl jump seat
Black scuff plates
Black vinyl steering wheel
Voltmeter, oil pressure/temp/fuel gauges w/indicator lights
Trip odometer
Inside hood release
Side window demisters
4 air registers
Electronic AM radio w/digital clock/2 door mounted speakers
Color-keyed instrument panel w/black appliques
Locking glove box
Cigarette lighter
Pwr point
12" day/night mirror
Color-keyed door trim panel w/black handles/reflector
Color-keyed cloth headliner
Color-keyed vinyl sun visors
Where does it mention weight rating ? - ticki2Explorer
enblethen wrote:
Rating is stamped on the inside of rims.
Wheel identification
No where in that link does it mention weight rating unless I missed it - It is a 6.0 inch wide rim the K indicates the type of tire bead.
~snip~
I am not sure how to interpret that data. That is, not sure what "6.0K" means. It seems qty=6 so assuming it is a dually truck, but cannot imaging each one has a 6K (pounds???) rating. That seems very high for each wheel. Consequently, If the total rating is 6K in that each one is only rated for 1,000 pounds then that seems awfully low. - jaycocreekExplorer IIMaybe they quit doing it but as I mentioned,mine was on the factory window sticker..example...
Pwr steering
Black scuff plates
Trip odometer
Inside hood release
4 air registers
Locking glove box
Cigarette lighter
Pwr point
Color-keyed vinyl sun visors - Grit_dogTrailblazer3500-3600lbs for most OE 8 lug rims
- billtexExplorer III have looked at GM and Ford OE wheels both alum and steel and have never found the rating marked on the wheel.
Good luck with your search.
