karenor59's avatar
karenor59
Tire and wheel weight ratings
I have a 10.6 Bigfoot camper on a 2000 Ford F350 crew cab long bed 4WD SRW. The rear axle weight loaded is 7380 lb. I want to put BF Goodrich TA KO2 285 75R 16 load range E tires on it. The load rating for these tires is 3750lbs. ea. for a total of 7500 lb. The load rating for the stock 265 75R 16 is 3415 lb. for a total of only 6830 lb. I can't find a load rating on stock wheels or find wheels this size that are rated for 3750 lb.
I want to use the BFG's because they have reinforced triple side walls. I travel on bad roads and have had trouble in the past with the failure of lesser tires.
Any suggestions? Thank you.
