FireGuard's avatar
FireGuard
Explorer II
May 22, 2019
Tire size/gearing for Ram DRW
I’m getting closer to pulling the trigger on a new (2018) Ram DRW Cummins 4x4 Aisin.
I want to go back to a TC in the 10’ range and flat tow my Jeep.
I’m comparing a Tradesman model with 3:42 gears and a Laramie with 4:10.
I think for my purpose of carrying a 5k lb camper and towing 5 k lbs, the 3:42 would be plenty and would be better running empty.
I would like to add bigger tires but I think as long as the diameter is similar it shouldn’t pose a problem.
The truck comes stock with 235/80/17 which is 32” tall and 7.4” wide.
If I went up to a 275/70/17 the height is only 32.17” tall but 8.8” wide and I think the biggest I would want to go with would be a 295/70/17 at 33.25” tall and 9.8 wide.
So from my understanding the 275 wouldn’t change the gearing and maybe add a little rolling resistance due to being wider. The other 2 being an inch taller would change the gearing but probably not make too much of a difference??
I would get new rims with the proper offset rather than using spacers.
The Laramie is the granite color which is my favorite but the Tradesman is silver and $9k less. I really don’t need all the bells and whistles but the Laramie is a sweet truck.
Let’s hear your thoughts, primarily on the 3:42 vs 4:10 issues.
  • My father has a 2015 6.7 with the Aisin and 3.73 gears. He finds he has to run in the upper 60s when he is pulling his 16k FW. He also finds with just his 5k TC he has to run at least mid 60s so it isn't straining. He wishes he had gone with 4.10s to bump the RPM up a tad while reducing speed a tad.
    I borrowed his truck and TC for a couple of days and put a few hundred miles to see how I liked a much larger rig since we are wanting to upgrade. I agree with him that the 4.10s would have been a better choice. I had choosen the 3.73 believing Tow/haul mode would lock out 6th gear. However, the 6th gear lock out seems to only be done with my 6.4 Hemi, not the diesel (at least not with the Aisin).
    If you are going up in tire size, I would definitely go with the 4.10s.
