kcfissel
Aug 14, 2016Explorer
Tire wear/pressure
All right you tire experts, I have a topic for discussion.
Lets say a guy replaced the tires on a light weight 26' trailer, dry weight 5200 lbs. +/-. The tires he was replacing were 20575R15 LR C which are rated at 1820 lbs.
He ordered 22575R15 Load range D, which upped the capacity by a rated 720 lbs. per tire. Maybe a bit of overkill, but should provide ample safety margin.
After the tires were installed he questioned the pressure and was told it was to be 80 psi. Why, he asked? I ordered LRD which is spec'd @ 65 psi. Well the tires we mounted were 10 ply, LRE.
Harrumpfh!!
These tires are rated at 2830 lbs capacity @ 80 psi.
So, if you are still with me, he's thinking the tires are too hard and will wear out the centers prematurely. What say you to running a lower pressure, to flatten the footprint, say 65psi for starters?
Harrumpfh!!
