mfoster711's avatar
mfoster711
Explorer II
May 22, 2017
Tires - Load Range D vs E
My trailer uses 225/75R15 load range D tires. Checked my local tire stores and all of them only had load range E tires in stock. One of the guys tried to push me into getting load range E because "they are a much higher load rating and can handle a lot more weight" and he questioned why I didn't just want the load range E tires. I told him I did not want load range E for several reasons:
  • Load range E tires have to be inflated to 80 PSI and might cause a rougher ride
  • my wheels are not rated for load range E
  • I would also need to replace my spare to ensure I don't mix load ranges
He was polite after that and ordered some load range D tires which will be in this week.
Truth being told, my wheels might be rated to handle load range E. I just didn't want the load range E tires because I thought it would be overkill for my trailer and may cause a rougher ride. My max trailer weight is 7500 lbs so I could actually use load range C and be just fine.
I am just curious how many of you would have just gone ahead and took the load range E tires they had in stock. Do you think it would make a difference in the ride?
  • If you installed "E" tires you could still inflate them based on the load they're carrying, not necessarily 80 PSI. It is a heavier tire and can handle more load, but should also last longer and provide that extra edge in tire safety. Regardless, I hope any tire you're installing on your TT are not China bombs. If so, cancel the tires and get a different ST tire, i.e. Maxxis.
    Also, be sure they get balanced.
  • Most everyone with D's want to switch to E's just for a little more comfort knowing they are a little stronger tire. To each his own on that theory, it could be argued all day.
  • I don't know.
    As for the rougher ride, you don't have to inflate a tire to its max. But, the E's may have a stiffer sidewall. I wouldn't sweat the spare. How often would you need that??
