Cummins12V98
May 08, 2020Explorer III
Dennisokey wrote:
What is anyone using for tires. It seems that I go through tires at about 25k. I keep vehicle aligned and tires rotated regularly, air at 80 PSI on rear tires. Trailer weight is 14k. No irregular tire wear. 80% highway driving, 20% highway towing. I just don't seem to get good tire wear. Any ideas?
Do you know your actual loaded and unloaded weights? Do you run 80 rear unloaded? Weigh loaded and unloaded. Use the weight inflation chart for your tires. Add 5psi rear and 10 psi front to what the chart says. I guarantee you will have much longer tire life.
Michelin MS2's
As far as towing being hard on rear tires well I guess it must be the tires! My Michelins look great even with 6k pin weight running 68 psi.
