- Grit_dogNavigator II
cummins2014 wrote:
ppine wrote:
Toyo, Cooper, Bridgestone
I have gotten 60,000 miles from Toyos on an F-350 doing a lot of towing.
I run my rear tires mostly around 60 psi.
I don't normally rotate tires at all.
I wish I would see 60K on my Toyo AT2's , fair amount of towing on my Ram 3500. I will be happy if I see 45K. rotated every 5K. They are run at 80 psi when towing the fifth wheel ,and 45 when solo.
Not sure what brand next, but it won't be Toyo, may try a set of Coopers
You are dreaming if you think you'll get much if any more than that out of a real AT tread tire, especially towing or hauling heavy even 50% of the time.
But like everything else, ones definition of when a tire is "done" varies. Driving habits, terrain, climate etc all vary.
However Toyo ATII and Cooper AT3 are a couple of the top performers. Along with the Goodyear AT with Kevlar mentioned above.
Also, if rotating every 5k, you might be doing your tires a dis service. Should be no need to rotate that frequently in most conditions (heavy Mountian driving excepted maybe) and how are you rotating? Just blindly rotating X pattern or just blindly dropping truck at the shop to have someone move the tires around?
If you learn to read the tires wear pattern and its differnet for different vehicles and conditions, and rotate to the optimal position to correct or maximize tread wear, it'll help.
One other tire worth mentioning, even though it's a MT tire and an unlikely candidate at that, is Firestone MT. Bought a set about 5 years ago, for winter tires. Was the cheapest non cheapo brand on Amazon that day, lol. Had them siped, inner tread blocks only. Then left them on year round. Truck mostly hauls camper and tows. Guessing they have around 35k miles or so on them and they are wearing awesome. Still 2/3 tread left and wearing beautifully. They might be the longest lasting tires all things considered I've ever had.
Guessing they're a very hard compound tire, but the siping allows them to have great traction as well. - cummins2014Explorer
Not sure what brand next, but it won't be Toyo, may try a set of Coopers - Cummins12V98Explorer III
alexleblanc wrote:
I swapped out my factory Michelin’s last summer as the we’re getting down to around 5/32 and really didn’t provide wet weather performance anymore. I went with General Grabber ATX in the factory size and have been extremely happy to date. They are very good in the snow and rain, as for wear it’s harder to tell as I’ve only got around 15000km’s on them currently but they have only worn down to 14/32 to date - should be a 60000-70000km tire.
Well i hope your Generals last longer than the OE's on my 11 DRW did. At 25k they only had 1/3 tread left and had a big tread separation on a front tire. - RedRocket204Explorer
Thermoguy wrote:
No one here has said Goodyear...RedRocket204 wrote:
I'm currently running Goodyear Wrangler Duratac now with about 25k miles and still looking good. I suspect I might get 40k miles out of them. My priorities were around load range E with decent traction on snow. - Me_AgainExplorer III
blofgren wrote:
Has Michelin discontinued the MS2 and the Defender? I don’t see either available for my truck on their website.
Did another search this morning and the LT235/70R16E Defender LTX MS is still listed. Chris - alexleblancExplorerI swapped out my factory Michelin’s last summer as the we’re getting down to around 5/32 and really didn’t provide wet weather performance anymore. I went with General Grabber ATX in the factory size and have been extremely happy to date. They are very good in the snow and rain, as for wear it’s harder to tell as I’ve only got around 15000km’s on them currently but they have only worn down to 14/32 to date - should be a 60000-70000km tire.
Just went on Michelinman.com and it has three tires for my truck Defender LTX MS2, LTX A/T2 and Agilis® CrossClimate. Put dually in and no Defender LTX MS2. Energy™ Saver A/S, LTX® A/T2 and Primacy™ XC, Ron was probably destroying to many Defenders on his duallie. Chris Thermoguy wrote:
No one here has said Goodyear. I am still running the stock Goodyear wranglers on my 2500 and have no issues. Just turned over 60K. Will need tires at some point but haven't decided when that will be. I do not pull as heavy as weight as you but over 50% of the miles has been with trailers 8-12K lbs.
Goodyear Adventure AT with kevlar are very good tires.- blofgrenExplorerHas Michelin discontinued the MS2 and the Defender? I don’t see either available for my truck on their website.
Stick with what works!!!
44,053 PostsLatest Activity: Jan 06, 2022
