Gdetrailer wrote:
nastyt wrote:
I noticed recently that the tires on the slide out side have been rubbing on the bottom of trailer. It isn't hitting anything but the fabric type weather covering thus far but obviously needs to be corrected. Any ideas on cause and any suggestions on a fix. Thanks for any and all help.
OVERLOADED.
Wrong size tires (did you or previous owner go to LTs?) Check the manufacturer specs and make sure you have to correct tire size.
Weak or broken springs.
Bent axle stub (the ends of axles where the bearings/hubs are which also could have happened while overloaded and hitting a curb or pot hole)..
Just to name a few possibilities.
Agree - focus first on what size tires you have and what size your supposed to have. I'm betting that this is not a new TT.
