rmnpcolorado
Jul 17, 2022Explorer
To a Suburban water heater from Atwood
I feel like a rookie asking this question, but we've always had Atwood water heaters and our new trailer has a Suburban. I've never had to deal with an anode rod before. With our Atwood, I installed a petcock and we drained the tank after every use-never had an issue with the sulfur smell.
On the Suburban, how do you go about that? We typically are weekenders except for our long trips where we don't empty the tank when moving obviously, so after the weekend we'd open up the valve and run it empty. Do you pull the anode rod out? Leave it full? Pull the low point valve and drain out as much as you can?
Like I said, we are not rookies, but going to be learning new tricks with a new rig after 12 seasons on the last one.
