Major_Dad
Jan 06, 2015Explorer
AirForceAngler wrote:rbpru wrote:
Here is a twist.
We have the typical power out, power in awning; it works fine, we use it a lot and it is push button convenient. However, I do not like the fact that it goes straight out and straight in. As the sun drops there is no way to lower the leading edge of the awning.
My niece had the same issue, so she ordered her new 5th wheel has a manual awning that you can set at almost any angle. Certainly not as convenient but a bit more practical.
The DW and I are thinking about adding one of the sunshade to ours.
We also have a power awning but ours can be lowered a bit by pulling down on one of the brackets on each side. I will lower one side a bit to drain off rain if needed. I am with you, though, I would trade it for a manual awning if I could. It doesn't lower as much as I'd like it to at times. If this one ever breaks hard, I'll probably be replacing with a manual awning.
The only mechanical thing I hate about our new trailer is the power awning. It only goes straight out and straight back in, and doesn't incline at all. If and when it fails, I will return to a much more useful manual awning.
Like others have said, NEVER NEVER NEVER leave your awning out if you are not with your RV. We saved ours in the nick of time during a pop up mountain thunderstorm in Colorado, while our neighbor who had left for the day had his awning beat up his Class A roof in the wind. I couldn't do anything but watch as the strong wind whipped the awning up and down; the force of the motion and the speed of the wind made it so dangerous that if I was able to catch the awning on the downward motion, it would have flipped me up on the roof with it.
44,068 PostsLatest Activity: Jun 27, 2026
