Rbertalotto
Aug 12, 2013Explorer
You should never obtain ground through the hitch. A seperate ground wire should be used in the trailer connector..
So let's review. Two pieces of metal with about 500 pounds of pressure are constantly rubbing against each other ....and we shouldn't lubricate why?
Ever put your hand on your coupler after a long run on a rough road....Heat is a killer!
