towpro
Feb 01, 2017Explorer
No charge wire was run. I did have to replace existing wires on toad from 5 pin connector back to tail lights, but only stop/turn, running and ground were ever installed.
I also had to install new break away switch but still need to wire that through to cab with banana plugs for brake buddy.
I still need to check out the coiled cable that came with Blueox. not sure how many wires in this coiled cable, or even what end is on other end that I need to interface with my Dodge. If I need to replace a cable end to 7 pin, and there is enough cables I will hook up charge wire, and if I find its needed, I can wire it from Toad end in future.
also waiting for parts from Remco. I need to move mount location of driveshaft cable so its a straight shot to drive shaft disconnect.
I ordered a replacement Wescon Fitting Assembly, and they recommended since I was already buying parts I might as well order replacement shifting blocks.
once I am done, I will take a couple test runs empty (but using hitch extension) since I don't load the camper until around Easter time.
I also found that I have the wireless transmitter for Brake buddy. this is supposed to tell me when toad brakes are applying.
