laidbackExplorerDec 10, 2014toilet problemSo our less than year old cougar has a problem, the toilet doesn't flush. When you press the foot lever the water barely trickles out, not nearly enough to get the job done. Water pump is fine, bo...Show More
chevyman2ExplorerDec 10, 2014check the toilet flush valve also. We get units in quite often with bad/damaged or cracked toilet flush valves
Related ContentSwitching toiletsWanting a Bidet for my Thedford toilet.Dometic toilet valave problemDometic toilet problemAtwood water heater problem
