laidbackExplorerDec 10, 2014toilet problemSo our less than year old cougar has a problem, the toilet doesn't flush. When you press the foot lever the water barely trickles out, not nearly enough to get the job done. Water pump is fine, bo...Show More
Old-BiscuitExplorer IIIDec 10, 2014Sounds like you have a Sealand ToiletHoles in rim could be cloggedOR inlet screen in water supply valve may be clogged (under side pedal cover where inlet line connects)
Related ContentSwitching toiletsWanting a Bidet for my Thedford toilet.Dometic toilet valave problemDometic toilet problemAtwood water heater problem
