FeatherFam
Oct 13, 2018Explorer
SoundGuy wrote:
RV toilets are available in all plastic or plastic with a ceramic bowl and are universally interchangeable. If you'd prefer the latter a model like the Dometic 310 would easily replace an all plastic model like the Thetford AquaMagic V and the kit includes a rubber seal that would allow for any differences in how the toilet sits atop the flange.
Thank you, I am aware of this. My question is about the integrity of the laminated floor which is substantially less capable of weight bearing versus a 5/8 plywood floor. I want to know if anyone has experience with adding the weight of a porcelain toilet to a laminated foam floor. Will a foam floor handle the added weight? The porcelain toilets weigh a lot more. I am concerned about how easily these floors bow, divot, and flex. The laminated floor is not a substantial design for weight bearing.
Like countless others, we have already had to take measures to mitigate the floor's deterioration caused by normal use. Actually, we baby our TT, and the floor still presents all of the tell-tale deficiencies common to laminate floors.
Do manufacturers put these nothing plastic toilets in for overall gross weight objectives, or do they use them because the floor will not handle the weight of a heavier porcelain toilet?
44,068 PostsLatest Activity: Jun 02, 2026
