FeatherFam
Oct 14, 2018Explorer
I received my floor diagrams from Jayco. Reading Jayco's floorplan design, parts, and assembly diagrams for our 23RBM, it looks like they used an 11.75" x 11.75" piece "plylam" under the toilet. The detail states: .5" ply and 1" foam. I guess that means there is an 11.75" laminated square comprised of .5" plywood and 1" of foam under the toilet.
The second stage of the floor drawing shows the main floor laminated foam sheets, and the toilet area 11.75" square is cut-out in this drawing; the space is blank. I would assume this means that the toilet area was designed with a reinforced square for mounting the toilet flange and supporting user weight.
That's what it looks like. There are also metal frame pieces in front of the toilet and to its sides. I will try to determine if the 11.75" "plylam" material is fastened to these supports. That would be good. If so, that should be a decent enough design. So now I need to find out if the floor was assembled as designed - Assume nothing, maybe assume that it was not. That's what I have learned.
44,068 PostsLatest Activity: Jun 21, 2026
