CharlesinGA
Oct 14, 2018Explorer
Was the toilet removed when the flooring was installed? Or was the flooring cut around the existing toilet?
As someone noted, the difference in weight of the two toilets is 13 lbs. You have much greater problems if the flooring is incapable of withstanding this insignificant difference in weight.
The all plastic toilets are installed by the OEM's for both cost and weight reasons, a few dollars on several thousand units adds up fast.
Charles
Charles
44,068 PostsLatest Activity: Jun 21, 2026
