Mandlemaker's avatar
Mandlemaker
Toilet wont flush
I have a plastic toilet in my hunting cabin. Normally, when I step on the pedal, the bottom of the toilet opens and water comes out around the rim.
Now, when I step on the pedal the bottom opens but no water comes out. When I crank up the pressure on the water line by opening the valve more water does come out around the rim without stepping on the pedal.
  • Lynnmor wrote:
    Mandlemaker wrote:
    What does the valve do? Why do I still get water when I turn up the pressure without pressing the pedal?
    It starts and stops the water flowing into the bowl.
    It doesn't stop the flow at higher pressure.
    This is all good information. You have a bad water valve.
  • What does the valve do? Why do I still get water when I turn up the pressure without pressing the pedal?
  • Lynnmor wrote:
    Sounds like you need a new water valve.
    And a proper water supply regulator.
    Throttling a valve does NOT reduce pressure....it just limits amount of flow
