rwbradley wrote:
I have also found the wooden block solution adds to stability. As I fully extend my jack, the front seems to sway, especially if the site is sloped nose down and the jack is fully extended. Having a wide base and extra height means the jack does not need to extend as much and it seems to me to be more stable than without.
x2.
There is normally more weight on the tongue than on the stabilizer jacks. So it will sink into the ground easier than the jacks. A big footprint helps.
We were given a set of rubber mats. I now like those better than wood -- do not soak up moisture.
