When replacing your tongue jack, do you get a jack that is more than your tongue weight? Example, my tongue weight is about 950lbs. Would a 2000 lbs tongue jack be adequate enough?
I'm going with NO. You tongue jack will need to raise more than the tongue weight. When attaching the springer bars, I raise my truck, and trailer high enough to make it easier. Sometimes that is pretty high. Were I you, I would go with a 4500lb jack. Mine is 3500lb and more would be better. It gets in a strain a lot. My next one will be 4500lb
