When replacing your tongue jack, do you get a jack that is more than your tongue weight? Example, my tongue weight is about 950lbs. Would a 2000 lbs tongue jack be adequate enough?
Ours is the UF 3500#. When it goes bad, I’ll probably go up. I turned ours 90 degrees and the tailgate will go down depending on the angle between truck and camper. Sometimes it hits the little useless light.
