knowles24
Jun 19, 2014Explorer
bnk190 wrote:
Nice idea. I'd like the setup with a 2" receiver on it so I can slide in my existing bike rack that I have. Then when not connected to the truck I can have my bike rack with me. Hmmmm might have to see about getting one built on that idea. It would extend out over the top of the LP tanks but when the bike rack isn't in that's not an issue.
So another reason that my 2" receiver is higher in the air is because of the contour of the front of my camper. I suppose I could have had the portion of the flat plate hanging over the front of the 2.5" tubing and gusseted on the front side, but I wanted to keep everything as far back as possible. That being said, I did modify the bike rack by cutting 10 inches out of the upright post. If you build one of these check that you have the clearance for the 2" receiver portion at the correct height for your bike rack. i.e. The bike rack bolted to mine would be very short in any other regular application. I also cut the bottom plug in piece of the bike rack shorter so it would sit flush against the A-framed rack I built.
Here's a picture that sort of shows the contour of my camper I was working around:
Here's a close up of the receiver portion on top:
