1964DeCamp's avatar
1964DeCamp
Tongue Weight (getting sucked in by trucks)
Hi, I have an old 1964 DeCamp travel trailer. The sticker says it is 2000 lbs...which I fail to believe. Last summer I towed it with a Mercury Mariner, which has a towing capacity of 3500 lbs... however, even with weight distribution, it still feels odd, I get sucked in and a bit squirrely when passing trucks, and going over 60 mph....is there anything I can do to help with the towing? Is this something that could be adjusted within the tongue weight? is there somewhere to have it weighed, or anything I can buy to help getting it to tow better? any help would be appreciated! thanks in advance
  • Truck stops, DOT highway scales that are closed. You can also do a web search for CAT scales, but those will cost you. First step, inflate your SUV tires to maximum pressure indicated on the tire sidewall.
  • You really need to get some accurate weights. SUV only loaded with family and stuff you would normally have for a trip, then SUV and trailer loaded ready to camp.
    It can be a number of issues from P metric tires to weights, to hitch weight. There is no one thing you will likely find, bit a number of issues.
