bikendan wrote:
waynefi wrote:
What happens with the tongue weight limit when you are using a weight distributing hitch?
My Tacoma says the the tongue weight limit is 650 lbs. Does that mean that if my trailer has a tongue weight over 650 I need a wdh, or that I shouldn’t pull that trailer even with a wdh?
The function of a wdh is to take weight off the tongue, right? How would you even measure the tongue weight with the wdh in place?
My current trailer has a nominal tongue weight of 380, but that is before water, a second battery, etc.
Your Taco's owners manual towing section should detail how much tongue or trailer weight, will require a WDH.
The Taco owner’s manual says I need a wdh for a trailer above 5000 lb, but it doesn’t say what tongue weight it expects for that trailer. My trailer is 3700 empty, but I still use a wdh.
