Crespro wrote:
Ron Gratz wrote:
Crespro wrote:
The sales manager makes this argument -- the regular hitch rating is 600#. With 1,100#, the Equalizer moves 200# to the trailer and 300# to the front wheels, leaving the spec 600# on the receiver. The Ford is 895 WD and 600# regular hitch.
I was not popular when I pointed out this problem. What do you think?
I would say the sales manager either is unaware of the facts or is intentionally misrepresenting the facts.
With a wheelbase of 119" and a ball overhang of 65", 1100# of TW would cause about 600# to be removed from the front axle and about 1700# would be added to the rear axle.
Assuming the distance from coupler to midpoint between the TT's axles is 240", restoring the 600# which was removed from the front axle would require about 600*119/(65+240) = 234# to be transferred to the TT's axles (at least, the sales manager was close on that guess).
The added load on the rear axle would be reduced to 1700-(600+234) = 866# -- probably enough to cause the rear GAWR to be exceeded.
The remaining load on the receiver would be 1100-234 = 866# -- which is not very close to the sales manager's 600#.
Furthermore, the receiver's rating is based on the TT's tongue weight and not on the vertical load on the receiver.
I think I'd be looking for a different place to buy a trailer.
Ron
Thanks very much. We are looking for another trailer that meets all of the specs.
I’ve dug into this issue a little. I spoke with a quality service rep from the Ft. Wayne truck plant (which produces ½ ton trucks, not 2500hd or 3500hd) and the preliminary answer I’ve gotten is the reason a 2500hd/3500hd standard bed (6’6”) truck is rated 500 lbs. less tongue weight than a 2500hd/3500hd long bed (8’) truck with the same hitch has to do with the difference in wheelbase. When I pressed him, he couldn’t tell me WHY 14” difference in wheelbase equated to 500 lbs. difference in TW rating, so I’m working on getting in touch with someone from the Flint Michigan assembly plant where they produce heavy duty trucks.
I’ve also been in touch with Terry from Hensley Manufacturing and he gave me some interesting information regarding tongue weight (I’m also going to contact Sean at ProPride).
Terry tells me there are two different issues in regard to tongue weight. The first is the TW weight designed into the trailer by the manufacturer which is 10% to 15% of the total weight of the trailer, but in recent years has gotten to be more like 10% to 12% to make trailers “half ton towable”. I checked the numbers listed by the factory on the TT we’re leaning towards and what they advertise works out to roughly 13% so he’s probably pretty close on this.
The second issue he talked about is the TW recommended by sway control hitch manufacturers which is closer to what we’ve been talking about here—12% to 15%. The reason for this, according to Terry (and he’s probably right on this too) is 12% to 15% is what is required for the sway control hitches to function properly. In other words, tongue weight is part of the friction that helps control sway on “conventional” sway control hitches.
What was interesting is what he said about TW and the Hensley Arrow (and presumably the ProPride 3p hitch since they both function basically the same).
“The Hensley Hitch is not a sway control hitch. We are not interested in trying to control trailer sway, or to regain control of a trailer that has already begun to sway. The Hensley Hitch does not use tongue weight in any manner to gain stability in a trailer. No matter how much tongue weight or little tongue weight you have it will always be impossible for your trailer to sway or fishtail when you pull with a Hensley. “
If what he says is true (and I have no reason at this point to believe it’s not based on how the hitch works), then when loading a TT using a Hensley (or presumably the ProPride 3 P) one could adjust the tongue weight closer to the manufacturer’s specs—which could make a big difference.
For example, the TT we’re considering has a GWR of 10,300 lbs. Say we (hypothetically) load it to 10,000 lbs. Using the recommended numbers for a sway control hitch (13% to 15%) splitting the difference at 14%, I should have a tongue weight of 1,400 lbs. which puts me right at the limits of most to the sway control hitches out there.
Now…if I load the same trailer to the same weight using a Hensley (or presumably the ProPride 3 P), if I load it to the manufacture’s TW specs (in the above case 13%) I’m at 1,300 lbs with a 100 lb. cushion. By the way, as a side note, according to Terry you DO NOT have to add the weight of the Hensley into the TW equation.
I had sort of had these “premium” hitches in the back of my mind since we’re looking at a much bigger TT, but this has made me want to take a closer look at them.
