LarryJM
Mar 15, 2015Explorer II
RCMAN46 wrote:LarryJM wrote:RCMAN46 wrote:Turtle n Peeps wrote:
The more tongue weight you have the better it will tow. As long as you are not over on any of your truck spec's leave it.
X2
This is a major reason 5th wheels tow better with pin weights in the 20-25% and sometimes even more.
The more tongue weight or pin the better.
The big guys have pin weights that often get near 40%.
I disagree with that conclusion. The MAIN/MAJOR REASON for the better stability and towing characteristics of a 5er is from WHERE the pin/hitch wt. is in reference to the TV rear axle and NOT FROM THE HIGHER pin/hitch wt.
Larry
Lower your pin weight to 10% where many tongue pulls are at then tell us how the handling compares to 20-25%.
That's a ridiculous statement since to get 10% you would have to GROSSLY misload a 5er to remove that much pin wt and has absolutely NO BEARING on what the major factor that makes a 5er setup more stable and that is the location of the tongue/pin wt to the rear axle of the TV AND NOT the percentage of that tongue wt.
Larry
44,056 PostsLatest Activity: Jan 12, 2020
