Yep I stand by my assumption that you will be fine.
You are correct that with a weight distribution hitch your receiver is rated for a total of 10,500 lbs and a max tongue weight of 1,100 lbs.
I always figure about 1,200 lbs with added clothes, food, water, and other camping junk. So you are at
5,620 lbs Dry
1,200 loaded for camping
6,820 total heck round it up to 7,000 for grins. that gives you
910 lb tongue weight at 13%
Trailer is rated at up to 7,600 so you are good there with 7,000 lbs.
Truck is rated at 9,600 so you are good there again with 7,000 lbs.
hitch is rated at 1,100 WDH so you are good there with 910 lbs.
I'm still saying in my opinion you're good with a 1,000 lb WDH.
You also have to take a step back and realistically figure on how the weight is going to get into the waste tanks. If you have say 40 gallons fresh, you're only really going to wind up with 40 gallons combined black and gray. The water in the waste tanks had to start somewhere and that somewhere is the fresh water tank; plus some of the relief after drinking the drinks in the cooler. So as you use the 40 gallons fresh, the water moves into the waste tanks. When the fresh tank is empty, the waste tanks will stop filling.
Figure 40 gal at 8.3 lbs per gal = 332 lbs.
Now if you are at a park with a fresh water hookup, you will be bypassing the fresh tank and will be able to put more than 40 gal in the waste tanks. But then again if you are at a park with a water hookup, they will also invariably have a dump station to empty the waste tanks before heading home.
