augustpilot
Jan 14, 2015Explorer
Topper for Truck
Have 2014 Dodge pu. New to trailer, could use more room for chairs, generator bikes, etc. thinking of a fiberglass topper, looking for pros and cons from owners.
Thanks
Thanks
mileshuff wrote:
I had an A.R.E. tonneau on my 2007 Dodge until I changed to a 5th wheel and had to remove it. Looked at many brands and felt ARE was superior to others. Really nice top. Now it sits in my garage till I find a friend or someone with the same model truck! I'd assume the ARE build quality of the topper shells are just as good as my tonneau.
Hoosier Daddy wrote:
I am not happy with the limited view out the rear window. Even with the side windows there is a big blind spot at both rear corners....and as previously mentioned with factory tinted rear glass on the cab and the rear window of the topper,night view is reduced even more. At night it's like backing into a dark tunnel!
'tiredTeacher wrote:That looks like an awesome option for a truck bed that performs varied duties! It's on my list for my next truck. Thanks for sharing!
My solution was to buy a Softopper. It is similar to a boat bimini. The sides and back can be rolled up for bed access, the entire top can be folded forward and down to accommodate tall loads, or the whole thing can be removed by pulling two circle clips if you need to make a trip to the dump. How many other caps are a one-man operation for removing?
The construction is tough, the fit is tight (no flapping at interstate speeds) and the versatility is outstanding. For the price of a top-of-the-line tonneau, you get a cap.
Here is a LINK
