dedub's avatar
dedub
Tork lift outside arms compatibility
I sold my Tork Lift tie-down arms with an old camper but still have the brackets installed on my 2005 F-250. I have an opportunity to buy a set of arms off of that the owner says fit on his 2004 Dodge 2500 and also 2001 F250 Superduty. Sounds likely to fit to me. Can anybody confirm or deny this??
Thanks
Using square tube made in my shop arms right now and not too proud of them....
  • I took the good advice here and called Tork Lift. Folks were very helpful. It sounded pretty iffy on the fit......straight vs. curved so I'm going to order from them for a grand total of 32.00 more (total) over the price on Craigslist. If anybody's in the market, there is a set of arms for sale on the Portland, Or Craigslist.
    Thanks for all the help.
  • Problem with the Torklifts app. guides they do not list the arms and the mounts separately, part numbers are for both. Generally its the mount thats unique. Your fronts should be same (arms) rear- one variable is hitch. but
    I will say this when I switched factory receiver (01 F250) to super hitch, I also ordered new rear mounts. The arms were the same as my old ones (and same as used on fronts) only the mounts attaching to the hitch was different.
    http://www.torklift.com/documents/appguides/application_guide.pdf
    but a call or note to Torklift should verify.
  • I think they only make the arms in two flavors; curved and straight. I know when I added side steps that extended to the rear wheel, all I had to do was swap out the part that's on the truck as the arms, the bent kind, were the same. Just the mount angle was adjusted down was all.
    So, my bet is; there are just the two styles and Torklift builds their bases to specific trucks to utilize the common arms.
  • My sense would be to contact Torklift. They should know, they made them.
