mike5150's avatar
mike5150
Tow Advice F150 1/2 ton
We are looking at a Wildwood 27RKSS Gross Weight 7720 lbs Dry Weight 6355 lbs My F150 as far as I can tell can tow 8000 lbs it is a XLT 4dr SuperCrew 6.5 ft. SB (5.0L 8cyl 3.31 E-Lock Electronic Locking Rear Axle Ratio Is this to much TT for this truck I know I am pushing the envelope we have never owned a TT before any help would be very much appreciated Mike
UPDATE I understand this is to much Trailer for my truck Just trying to learn so
The yellow Sticker Door Jam says The combined weight of occupants and card go should never exceed 1661 lbs Is that the magic number for total hitch weight of TT and passengers and gear If so does
  • mbopp wrote:
    Short story - not enough truck. It's not about the tow rating, it's about payload and especially rear axle rating. And this is compounded by the fact this is a S-crew - how many people and how much gear are you hauling?
    What's the yellow payload sticker on the driver's door frame say for your rating?
  • goducks10 wrote:
    You'll be around 7000lbs by the time you load up propane, batteries, food, clothes and gear. Maybe more. Tongue weight will be around 900-950lbs. It will be a load with the 3.31 gears. BTDT with a 2010 F150 5.4 and 3.73 gears. I know the 5.4 is down on power some compared to the 5.0 but with the 3.73 gears I'm betting it pulled as strong. You'll be in 5th and 4th most of the time, which is not that big of a deal. BUT @33' long and weighing 7000lbs it will move that truck around. Especially with the stock P rated tires which have squishy sidewalls to give the truck a nice soft ride.
    If you do get that TT you should invest in a top quality weight distribution hitch. Something with built in sway control.
    JMHO but I wouldn't want to tow that heavy and long of a TT with that truck for longer distances. I would do the shorter trips like 50-75 miles one way. But if you're planning on doing some long distance traveling like 2-3 days of traveling then I would suggest something smaller or a bigger truck.
    You should also check your CCC sticker on the door jamb. Lots of times trucks with the lower gears have lower payloads. If you're in the 12-1400 range and drop 900lbs on the rear of the truck you won't have much left for passengers and gear in the truck.
    Good post here! Truck will work for a weekender that stays close to home, but not best for long distance towing.
    Jerry
  • You'll be around 7000lbs by the time you load up propane, batteries, food, clothes and gear. Maybe more. Tongue weight will be around 900-950lbs. It will be a load with the 3.31 gears. BTDT with a 2010 F150 5.4 and 3.73 gears. I know the 5.4 is down on power some compared to the 5.0 but with the 3.73 gears I'm betting it pulled as strong. You'll be in 5th and 4th most of the time, which is not that big of a deal. BUT @33' long and weighing 7000lbs it will move that truck around. Especially with the stock P rated tires which have squishy sidewalls to give the truck a nice soft ride.
  • With a 7720 lbs GVWR trailer you are going to have about 925 lbs of tongue weight. Now you need to know what the yellow door sticker on your truck says. That will tell you if you have enough truck.
  • like others mentioned you need all the info. Payload is where it's at, you will run out payload long before you max out tow capacity and the closer you get two the maxes the less enjoyable the tow is. From the info provided my guess is it wont be a pleasant experience.
  • Really need to know the GVWR of the truck. However the 3.31 rear is a tow cap killer
  • I think a SuperCrew Cab, 5.0, with 3.31 gears would also be a hindrance.
  • Your max payload capacity is 1455 lb. If the tongue weight is 1150 you have only 300 lbs left for cargo, passengers etc. Not enough wiggle room.
  • Max case, you could have around 1150 lbs of tongue weight. What is the payload capacity of your F150? How many passengers will you have and what do they weigh. How much stuff are you going to put in the back of the truck and how much does it weight. Don't forget that your hitch and weight distribution unit will add another 100 lbs to the sum of all those.
    Forget the "tow capacity"... just a mfg sales gimmick. Payload capacity, RAWR, and GVWR will be the figure you need to be concerned with.
    Good luck
    Ron
    ps... you're looking for advice....not advise.
  • Short story - not enough truck. It's not about the tow rating, it's about payload and especially rear axle rating. And this is compounded by the fact this is a S-crew - how many people and how much gear are you hauling?
