ib_leblanc
Jun 24, 2013Explorer
Tow haul mode?
Pulling 10,000 lb fifth wheel with f350, 6.4 deisel.. do you have to always use tow haul mode even on flat interstates?
Cummins12V98 wrote:
Every time I start my truck I hit the TH and EB buttons. Keeps the line pressures up un the trans and keeps the trans from going into too high of a gear and lugging, example 6th at 45. Also allows the EB to work the best so the brakes last longer solo driving and also slows the trailer when towing. Also keeps the turbo/EB working properly.
Where is the EB button?
Jim and Barb wrote:
What I have read the Tow Haul is to lock up the torque convertor in the transmission. Without going to deep in it basically this reduces the fluid resistance that turns the internal parts that make you move. By eliminating this this will greatly reduce the heat in the transmission. This will reduce the problems associated with excessive heat problems and repair bills. With that being said I engage the button when I start the engine when I am towing. I tow with a 2006 Dodge 2500, 5.9 Cummins R 48 transmission with an added after market Aluminum transmission pan designed for cooling.
If you are asking about Ford I don't know. On my Ram it is next to the TH button on the dash.
Allworth wrote:Not with my current truck I won't do that. I connect, put it in "D" and go. I push it occasionally towing or solo.
The company would not pay to install it if they didn't think you should use it!
Trailer connected --- Tow/Haul on!
