ib_leblanc
Jun 24, 2013Explorer
Tow haul mode?
Pulling 10,000 lb fifth wheel with f350, 6.4 deisel.. do you have to always use tow haul mode even on flat interstates?
larry barnhart wrote:His loss. Too bad you'll still have to listen to him cry after he smokes the transmission
I cannot understand if any body feels they don't need the tow haul mode when towing. Friend just told me he does use his but not all of the time. Then he said I really don't know what it does. I tried to explain but I ended the story in the middle because he wasn't interested enough to listen.
chevman
I can't speak for the Fords, but on my Allison, TH mode bumps up the shift points to a higher rpm and locks the torque converter sooner. It also engages auto-downshift. If I'm towing on the flat, I'll turn it off as I approach my target speed (usually around 60 mph) so it will hit OD sooner, then turn it back on to to handle any grades. YMMV...
Lyle
rattleNsmoke wrote:
With your TorqueShift Ford tranny, your shift points are electronically altered to keep your engine in peak torque range while towing in lower gears. Once your at highway speeds there's no difference in RPM's in or out of T\H mode. Click it on and forget it.
