Terryallan
May 08, 2020Explorer II
jerem0621 wrote:
If I was waking into a 7,000 lb trailer and didn’t already have a TV I would opt for a 3/4 ton truck. The 7,000 lb dry trailer will be 8,000-8,500 lbs. loaded.
That being said, if you can find a F-150 with 1700-2,000 lbs of payload and the 5.0 Coyote (the 3.5 EcoBoost is a fine engine, and I would not be afraid of it at all) and 3:55 sir better axle ratios you should be okay.
JMHO based on experience.
Thanks!
Jeremiah
Said it was 7000 loaded. And as you said, would be fine with a 5.0, and 3.73. That is what I have, and it does GREAT. Problem is. they are few and far between. Most 150s now come with high MPG gearing, and low GVWRs. I looked at every new F150 on my dealers lot last trip, and the highest GVWR I could find was a 7050lb. There was not one 3.73 on the lot. And the only 3.55 came with a EcoBoost. The rest were all 3.35, 3.15, and higher. They wanted to trade.
I told them they didn't have a truck on the lot as good as mine.
BYW. i was there for a oil change
44,072 PostsLatest Activity: Aug 23, 2026
