Ejraste
Jul 06, 2020Explorer
Tow weight
Im new to the rv trailer world. I am currently in the market for my 1st travel trailer. The idea is to eventually find a full time/seasonal campground that has full amenities. I have small children an...
Ejraste wrote:Put everything you can in the trailer, it only adds 12% to the tongue weight. 100 pounds put in the trailer instead of the truck only adds 12 lbs to the tongue weight, you save 88 lbs of payload.Jebby14 wrote:
keep in mind fully loaded that trailer can be as much as 7900 lbs. (it has a decent amount of carrying capacity at 2865)
giving you a tongue weight almost 1200 lbs.....
depending how you load it (and the rest of your stuff) you can likely do it but i would expect a less than enjoyable towing experience. i would suggest buying the best hitch and sway control you can afford. another thing not mentioned here is to make sure your brakes are up to snuff as that 3.3 is going to struggle to hold the weight back with compression coming down hill.
Very true and i would not max out the trailer with cargo. I would take a separate vehicle to help with cargo as we only want it for a seasonal type campground to go to each year. So I would def keep the numbers low.
