APT
May 15, 2017Explorer
My TT is 28' box and fairly lightweight at 5500 pounds dry. I would not recommend towing my TT with any mid-sized vehicle.
The Grand Cherokee's towing limits are a little over 7000 pounds. The receiver limit is right around 750 pounds, which is about 6000 pounds loaded and 5000 pounds dry. With 750 pounds of TW, you need to be careful of how much weight is inside the cabin before exceeding the payload, which my understanding is under 1200 pounds.
Cost wise, a crew cab half ton is about the same for similar equipment in a mid sized SUV, hold it's value far better, and will tow with proper equipment much more comfortably.
44,056 PostsLatest Activity: May 04, 2014
