- romoreExplorer IIForget dry weight, it is meaningless for our purposes. By the time you add propane, water, food, clothing etc etc it will be north of 3,000 lb. What is the towing capacity of your vehicle from the door sticker?
- LwiddisExplorer IIAt max weight each of those two tires on this single axle TT will carry about 1750 pounds. What is the max load on the factory supplied tires? My TT weighs 5200 pounds loaded and wet...about 1250 on each tire..hint hint.
- LwiddisExplorer IIDry weight doesn’t mean anything. 3500 minimum loaded and wet. What is the Liberty”s payload and max trailer weight? “Pulling?” My daughter’s Volt will “pull” it.
44,054 PostsLatest Activity: Aug 13, 2015
