Kayteg1
Nov 02, 2020Explorer II
TRIPLE8 wrote:
Hi, for only 3-500 lbs of tongue weight you will be good. The 48" Torklift extension is good for up to 600 lbs without weight dist.
I would not exaggerate it.
I had aluminum dually with 12' TC on it without modification and with camper only rear still was 2" higher than front.
But when I put 48" stinger on it and hook my 3500lb boat, even with tongue in the range of 300 lb, I was scratching driveways with end of the stringer.
Mind my stinger is straight 3" tubing mounted in factory receiver.
Torklift Supertrust add 2nd beam below, so additional 3" drop.
